RCU Forums - View Single Post - Control line comeback
Old 12-28-2023 | 08:27 PM
  #113
GREG DOE
AJ, You're certainly holding up your end regarding posting: "I wish more guys would post seems, like I invaded this circle thing." A quick count shows that you were the "LAST" to post on no less than 26 threads. Congratulations that's probably an all time record! Your spelling, and punctuation could use some work. I've been following your posts since you exploded on this forum, and I've been tempted several times to comment, but didn't want to come across as confrantional, or even a bully. That's not who I am. I made a suggestion for a simple battery/starter build which didn't suite you, so I figured I'd let others read and respond to your posts. I've pretty much done everything there is to do in Free Flight, Controline, and RC (except helicopters), but I usually let others respond first, because I'm smart enough to know that there is a lot I don't know. Page 2 of the November issue of Model Aviation has a picture of my son and granddaughter at this years NATS. I had planned to be there, but my arteries had other ideas, which required a bypass. I'm probably in the minority, but I'm seriously not interested in where you get your bellcranks, how the cowling on your Ringmaster is shaping up, and what size fuel tanks you have settled on. If you are getting dizzy why not just stand still and fly figure 8's for a couple of minutes? I wish you well in your modeling ventures, but have a gentle suggestion. Consider if your audience here would care if I posted how I repaired a broken landing gear on a night Vapor, vacuumed bagged the wing skins on a EF1 pylon racer, or install a firewall in a fiberglass fuselage. Now if someone asks, then I'm happy to share how I do things, which might be different from how someone else might do it. Finally I commend you on how prolific you are as a poster on this forum. With all the other things you are involved in, it's amazing to me the volume of material you find time to post. Happy New Year.
