RE: Aligning everything
I want to add ,like Randy said, that the tricky part is ligning up these measurements, for these areas I use epoxie which gives you enough time to align things up, I then pin these areas to stay in place, at the same time use blocks. I keep an eye while the epoxie is curing so nothing has changed or moved. I use the 30 mins. epoxies for strength and time.
Garthwood.
