Tailplane you could use 15mm servos if you redrill the mounting angle brackets. Rudder needs full size.
Wing you would need to remake the mounts, but it could be done. Remember it’s not just servo torque, the 15mm servo has smaller gear teeth, so they are weaker.
In the U.K., MacGregor servos are the popular choice.
