ORIGINAL: Tipover
Dirtybird,
Just curious, how are you measuring your engines rpm while in the air.....as in flying?
Kevin
The early RCS 140 came with a 9000RPM cut off built into the ignition system. Because of this I could not use a 16-8 and went to the 17-8. It still would hit the cut off if I used full throttle.
