Yea, that 10 post thing before pictures is a bit rough when trying to get help, but if you have a multimeter you should check for continuity across the switch with no battery in and check for voltage with the battery in. Also make sure you have also replaced the AA batteries as well and that it isn't corroded, and those tiny wires are solid on the switch/board too.
