Originally Posted by
JRSmith
If you don't mind, could you share the part numbers you ordered? I plan on running the same prop setup and did Christian put the nomenclature and paint the prop arcs? Thanks.
yes he did all of that.
Note I purchased a spare set of painted and balanced blades as well. Hold on to your wallet if you go this prop route. Not sure what I was thinking at the time but the money is spent .
Maximum RPM
1/min Drilling(hole)/ EURO
Qty It.-No. Si. Description electr.| gas Diamtr.(rotor) ges.
__________________________________________________ _______________________________________________
1 31432 32i 3-Blade-Hub - | - 14.0 Millimeter
1 SS70-32K 32i Scale-Spinner Cup 32i - | - Diameter: 70mm Small, M4
1 777777 32i Adapter Threaded Rod - From M4 up to M5
1 F10YY32 32i Special-Motorflansch 32i, Vers. B - | - Di=10mm, 6xM5 im TK=40mm
6 744-32 32i CFK-Propellerblade HS 6200 | 5900 29.3" 74.40 cm
6 999999 32i Cut Down & Balance of Propeller Blade - D=620mm
6 888888 32i Paint-Work of Propeller Blade Tips - Double white / red
