RCU Forums - View Single Post - using a Perry fuel pump for nitro to gas conversion
Old 02-13-2024 | 08:28 AM
mgnostic's Avatar
mgnostic
The biggest problem will be with the needle valve. You will have to set it quite a bit differently since the engine will burn less gasoline by volume. You will also need to run a higher proportion of oil to gas than is used with larger gas engines due to the magnum having a bushed connecting rod.
