Originally Posted by
Raleighcopter
I was thinking it would make a pretty good aspiration pump.
On a slightly different topic, I replaced my transmitter with a frsky x18s. It's a nice transmitter that runs ethos instead of opentx. Problem is the curves only allow you to select integer values and opentx obviously had fractional steps between the I teger values on curves. This lack of curve resolution had me chasing a proper mixture curve and the steps are big enough that it jumps right over the peaked rpm when tuning. I've added a fine tune curve to get the resolution and am currently waiting for it to get above 50f to go attempt to tune the mixture curve. Anyway, be aware of the issue and I'll report back if my solution worked.
It would be nice if they I creased the curve resolution to 1024 steps so it aligns with the stick and output resolutions.
Dang... That is something I would NOT have expected from Ethos... Bummer, hope you solve it.
