Adjusting the paddles on aerohawk
According to the aerohawkmanual the paddles shall be adjusted so it's horisontal to the ground and the main rotorhead. When I adjust the paddles like this and then turns the mainrotor 180 degrees, the paddles will not be horisontal to the ground anymore..When I turns the rotor 180 degrees one more time the paddles are horisontal again.
What can I do about this? In what position shall the paddles be horisontal to ground/main rotorhead?
