Originally Posted by
sskianpour
Having some trouble with the added drop tanks for my hawk-100 along with the pylons for them. The way they mount to under the wings is by screwing in 2 blots to the wing that have big heads and are about half inch. And the pylons have pre-cut out keyholes in the fiberglass and you have to guide the pylon hole over the bolts, slide the front and back keyholes down over the bolts then tightening them by pulling the pylons the other way towards the direction where keyhole gets narrow so the bolt slides into the narrow spot and holds.
Mine dont hold, they Keyhole is loose and the grip is wobbly on the pylons. The area where the bolt mounted on the wing is supposed to slide back into the narrow keyhole part of the pylon is obstructed by white glue in irregular intervals internally in the pylon. I haven't even gotten to the tanks yet. @Alfa did you find a better mounting system? Like something that I can screw down instead of yanking on a pylon to pull it into a narrow keyhole section and hope it holds?
Also the bolts are machine screws but seem to be screwing into hard ply which isnt going to keep its grip and thread long. I would have hoped there would be blind nuts on other side but no there isnt. It's going to hold for 40 flights and then one side will depart after the wear and tear between machine bolt and wood and a drop tank will fly off.
HELP!
Use some thin CA on the wood hard points in the wing to harden it. Once is cured, the screws should then hold with no problem. I know what you mean but the irregular glue inside of the pylons. I have the same problem with the Yak 130 I am building. I plan to get inside of there with some hysol and a toothpick and try to even it up.
Tone
