RCU Forums - View Single Post - Yi tech. 4k and 4k+ action cams
Old 03-10-2024 | 04:02 AM
dleesomerset
I haven't personally unpacked firmware to correct code errors, but I understand the temptation to find a DIY fix when official support ends or isn't helpful. If the manufacturer has stopped updating the firmware, your best bet might be to look into online communities or forums where tech enthusiasts gather to share custom fixes or workarounds for similar problems. Sometimes, you'll find that someone has created a solution for the exact issue you're experiencing. Just be cautious, as tampering with firmware can potentially cause more issues if not done correctly. It might also be worth exploring alternative camera options if this becomes too big of a hurdle to overcome, especially if you need reliable voice control for your video work.
