RCU Forums - View Single Post - Wind RC Rafale
Thread: Wind RC Rafale
Old 03-28-2024 | 07:59 AM
GoldenEagle1
Tank and UAT as provided. I removed the tank to inspect and install my own fittings as those provided were too small in my opinion. The tank is really stout and no leaks after pressure testing. I've only used fiberglass/kevlar tanks before but this one might be better. Forgot to check the capacity before buttoning everything up but will verify later. Tossed the plastic UAT for the Digitech I installed.
Digitech 8mm clunk with heavy walled viton tubing - no brass tube. Replaced all the tank fittings with 8mm - was 6mm from the factory.
