Originally Posted by
maillemaker
I'm curious why half the smoke line is white all the time as if it was full of smoke?
And doesn't the smoke unit burn up with no airflow going through it all the time?
There is smoke in the line and will slowly leak out if left on for a long time. I'm planning on hooking the heater up to an RC switch so I turn it on when I plan to use it, off when I'm not. The wattage rating of the heating element will determine if it burns out, with the right voltage it may stay on for a long time and not burn out. Depends upon what is used as a heater, wire, resistor? I have an adjustable regulator connected to the heater, you can see the digital readout above right of the motor. I'm looking at a larger smoke unit for more smoke and wattage. Still testing...
