RCU Forums - View Single Post - Determining Correct 3-Bladed Propeller For OS 55AX Engine
Old 04-14-2024 | 02:19 AM
1967brutus
Originally Posted by J330
General rule for going from two to three blades is drop one inch in diameter OR drop an inch in pitch at same diameter. 11X6 three blade works.
My way of selecting a 3-bladed prop for an engine is as follows: Assuming a proper sized 2-bladed prop, plus its RPM is known for the engine, enter those data in any decent propcalculator, and note down the power generated.
Now search that same propcalculator for a 2-bladed prop that absorbs as close as possible to 2/3rd of that power at the same RPM. That is the size of 3-bladed prop you are looking for.
If APC is the brand to go for, indeed an 11 x 6 would be very close to an APC 2-bladed 12 x 6. Slightly heavier.
However, a Master Airscrew for example, would need to be 11 x 7 in order to be equivalent to a 2-bladed APC 12 x 6.
When going from 2-bladed to 3 bladed, it is always advisable to select a prop with a bit more pitch, the higher velocity of the propwash compensates a bit for the narrower diameter of that propwash, and flight performance will be more similar. At least, that is my experience.
