Follow up on the subject. when i loosened the mounting screws i felt that nose gear worked a little bit better but still needed somehow high pressure to close.
Another issue has now appeared as nose gear door is closing before the leg jamming into it. i tried to insert a restrictor on the out line of the door to slow it down but it didn't work.
This is quite frustrating, i haven't been in such an awkward problem before this installation.
