Originally Posted by
flaz
Yes these are AMP connectors. You can get these from Aeropanda, or with a little legwork, you can source them yourself from other places like Digikey. That is where I got them when I rewired Andrew's Flash after purchasing it.
Thanks for the info.
Does the connector lock in really nice after connecting both the ends?
I do see the locks on the end of the pins, hoping it locks in real tight.
I am going to use the powerbox standard premium cables (not the maxi) i see they are quite thin and i will have to add a heatshrink to make the wire diameter bigger to be able to crimp on the pins.
