RCU Forums - View Single Post - Veco Tom-Tom
Thread: Veco Tom-Tom
Old 04-24-2024 | 07:03 AM
  #53
AJ Sun
Wednesday and the wing assembled well, broke two leading edge ribs installing the 1/8 x1 inch forward spar. The rear trailing edge fit really well. Only way to glue this assembly is to thin the Sig glue and lay it in the crack. Of each assembly point by laying the wing vertical applying the thinned cement and letting it set over nite flip the wing over and do the same application to the other side. It’s spruce and Balsa so it should wick I hope. Also assembled the forward fuselage assembly. Landing gear and fire wall, engine rails. Thirty minute Epoxy and clamped.AJ
