Managed to remove the Tom Tom of the building board looks nice and straight, now to finish all the wicking, my thinned Sig bond is doing really well, better than I expected. Cut the wing to fuselage attach plates. That's a trick bonding at the training edge over nite dry then applying all four pieces. Top and bottom. That take time then using ammonia water go bend the four pieces to the leading edge. After costing the balsa. Having to mod the bell crank mount to include that center section from the trailing edge to the front source spar.AJ
