Today I installed the belcrank wood mount. It's thicker and is inserted from the trailing edge to the rear 1/8th square bottom spar to the 1/8th by 1 inch forward spar. With a 1/4 inch square reinforcement, off that forward 1/8 th spar. Should be strong enough. I also installed all the fuselage formers. A little progress is going well.AJ
