Ya Hye, I can post photos on messenger but not on the program for this. It just will not transfer. The wing is about complete and after some sanding and adjusting I will mate it to the fuselage. A lot of it is sand and fit. I installed a three inch bel crank had to come little modification go get it to clear and fit. The tail section elevator and push rod assembly will take some doing, to clear. I did not use your bel crank wood mount. Made a thicker one and it went to the training edge and mounted off that 1/8th x one inch forward spar.AJ
