Originally Posted by
bandit_av
I had the same problem with my Bandit canopy, Which I bought second hand from someone, and the canopy was full of glue marks, and I was really thinking of ordering a new one
so, carefully I sanded the canopy with #500 water sanding to remove the glue, after that with 800 to softened the sanding squirrels went up to 3M trizac #1500 #2000 # 2500 and in the end again 3M trizac #3000.
after the whole sanding prosses, I use polish cut compound, and in the end soft polish. It took me a lot of time and patience, but in the end the canopy is like new.
Thank you for your input but may i ask you what is the "polish cut compound" exactly?
