Originally Posted by
Boomerang1
Cut a piece of 3 mm ply & cut the front to a point to fit into the nose of the model.
Then glue some balsa block to the top & bottom of the ply & sand it to a cone shape to wedge into the nose of the model.
This will secure it up & down & side to side.
At the rear secure it with some screws to some hardwood glued to a former or some hardwood glued to each side of the fuselage.
Hold your batteries in place on the ply with some balsa strips & zip ties. This idea worked fine on a Savex F-16.
