RCU Forums - View Single Post - Veco Tom-Tom
Thread: Veco Tom-Tom
Old 05-08-2024 | 09:01 AM
  #64
AJ Sun
The build is going well made a few mistakes but I’ve been able to correct them as I go. Wing is done and about ready to mate it to the fuselage. Tried to bend the rod from the Control Bel Crank to the Elevator. Going to have to redo that just binds at several points. Trying to get it to move with out binding. Wanted to use a threaded Clevis at the elevator so I can adjust the movement and mount the Clevis at the Bel crank by soldier it in place. Has to have a bend to clear the wing trailing edge. I made that thicker and wider to prevent the wing from twisting and flexing. Also used a cap leading edge. With a spruce spars and leading edge of spruce.AJ
