Got the wing mated and the elevator control rod installed ended up cutting another 3/4 inch and resoldier that rod. Used Thirty minute Two part epoxy. I will do some Balsa filling and try to reinforce. Lots of open areas and sand to fit with some fill required. The wing flap was omitted with the wider trailing edge. If the elevator is in trim I will Epoxy that tomorrow. And do some weighting. The balance point is at the down elevator lead out. That’s a start two and one half inches from the wing leading edge. AJ
