RE: awwww, wook at da widdle baby........
if you know how to drive and tune you wont be able to flip a tmaxx... and if it is a tight teck. track then all you have to do is lock the rear diff. and then you can "power slide" around all of the tight turns!
to drive around a track with a locked diff you need a high level of skill!
but once you can do it then you will fly around the corners.
