Originally Posted by
speedracerntrixie
FYI, the normal servo plug will plug into the TX power input connector. You would just need to be careful as it is not polarized and if you get it backwards the TX is toast.
So, I have had 4 different lipo packs wired for TX use, they all have come with a standard servo type lead,,, the Futaba TXs only have two pins for it battery connection, unless spectrum is somehow different, if you plug it in backwards, one pin just doesn't plug into anything,, you can't plug it in reverse polarity with out purposely modifying the plug
