Originally Posted by
roydefiant
Tassos, I agree there is some controversy on the use of fuel filters, especially if one filters your fuel and using a UAT with the capacity to act as a filter. Tight fit to place vertical and I actually debated whether to put the intairco filter inline. In the end I decided to go with the filter as it is a large capacity one with 6mm inlet/outlets.
soon will be spraying the matte clear on and will post pictures when I get the model done and outside. Tassos can you remind me, are you flying your F16 with tailerons and flaperons and when your flaps are down are they still functioning as flaperons or fixed and just tailerons working?
thanks
Roy
Yes exactly, flaperons and tailerons together. It works very well. Even when the flaps are down, yes.
All the best, Tassos
