Originally Posted by
mongo
first,
an outlaw is NOT necessarily an anarchist.
even outlaws have some rules.
second,
now that we are allowing a rule not to be enforced at a non FRIA location, what rule is next to be not enforced at some select location?
turbine waiver requirement
greater than 55 pound without over weight build inspection
no alcohol consumption while flying
the slope is slippery, once you have stepped even a little way out onto it.
who decides where and when to stop, and can it even be stopped, once the "wall" has been breached?
The FAA. Since they are the ones that approved this exemption. I fail to see how this affects the other rules you mention as AMA rules and an FAA exemption are two entirely different things.
