Originally Posted by
Racer686
I used very little if any down trim on the landing flaps, it will balloon if you are still moving at a good clip but settles nicely with full flaps. I moved the 2200mah turbine battery under the deck and used 2x 2200mah 2s in the nose tray and one on the side tray to balance with the supplied jig.
Where did you end up with the GC? as recommended with the jigs?
I got my Matrix A few weeks ago, I know it will not take long to get together, but I have had a lot of things to do. No VT on my jet. and I am going to build it as light as I can, and use a KT130, I am at sea lever so it should make for a good flyer. I hope. When I get it all up, I will post some photos,
thanks Terry G
