RCU Forums - View Single Post - Flysky thoughts
Thread: Flysky thoughts
Old 07-23-2024 | 04:21 AM
JIMHI
Default Help
Okay I took the little TX out for a range test the other day and only got about 150 meters. I thought to myself that does not seem right so I went home and proceeded to reroute the RX antennas. Went back yesterday and received same result. I have another RX on the way so I can switch them out to see if that is the problem I thought. In the mean time I started doing some digging online. Turns out the TX is supposed to be using RF range of 2.408 to 2.475 but mine is showing 2.400. Also it is showing that on the RF mode it is using carrier only and using the left antenna only. This seemed odd to me so I tried to change any of those settings. When I change them and then go out of that screen and back in it has changed them back to what I found originally. I am a loss here what to do. Any help would be appreciated.
