Good evening guys. Forgive me for the long break but I had some problems that prevented me from continuing with the test. I take this opportunity to continue while waiting for the holidays that will inevitably lead me to a further break. But you will see that we will get to the end. In the meantime, let's conclude with the topic of servo controls that we interrupted some time ago. It seems to me that I have already explained a lot to you but there are a couple of things that I still have to tell you. The first concerns programming: I have already explained to you that the graphical interface of the Yantrs software is truly complete and many parameters can be changed but this, in addition to being a good thing, can also be a problem for those who do not have the necessary skills to understand what is being changed with the software. My advice is that once a new servo is connected, it is best to save the default parameters that are provided in the software: this is because I have noticed that there is no possibility of restoring the factory values after having made the changes and saved them on the servo. Another thing: after having made the changes to the parameters you will first have to apply them (“derived parameter”) and then write on the servo (“writinbg device”) otherwise it seems not to go well… The last thing that I have already mentioned is the fact that these servos are equipped with a 25mm aluminum bracket that is very nice and in the same color as the servo, but it is a bit short especially for those who want a lot of travel in the aileron and quote...
