RCU Forums - View Single Post - side carb DLE 30
Old 08-05-2024 | 07:00 PM
MoSo
Default Side CArb DLE 30 - Carb Rotation
Originally Posted by Lifer
I've been running my side-draft for about 7 years with no problem.
I am about to purchase a side card DLE 30. Never used one before. Is it possible to rotate the carb to the opposite side without ill effects? Reason being, we usually mount engines inverted. In this case of a side carb, it will be pretty difficult to adjust H & L end needle valves as they seem to be facing down when inverted. Hence, the reason to rotate to the opposite side. Then, when mounted inverted, the carb valves will be accessible
Also, are costs of replacement parts such as carb and carb interior parts (gaskets, repair kit etc) similar to the rear carb DLE?
Trust I am clear.
Chers
Mo.
