RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 08-24-2024 | 04:02 PM
  #2151
Jim.Thompson's Avatar
Jim.Thompson
Originally Posted by Raleighcopter
Black market m-tronic carbs are all over AliExpress for black market prices.....................
Very interesting!
Originally Posted by 1967brutus
Like the others have stated, it is NOT possible (at least not without great effort) to modify an existing Walbro carb for use with the solenoid..
Understood!
What you need, is an equivalent to your current carb Stihl M-tronic carb, or one at least compatible to your engine.
Since Stihl uses a different bolt pattern from Walbro, you will need to do some modding here and there.............
I don't expect the bolt pattern to be too much of a problem as my carb insulating block(s) is/are hand made; I can simply make another one with carb bolt spacing to suit..
Mind you, you still need a TX with good curve programming functions, and you still need to determine those curves yourself.
I have OpenTX transmitters that will solve that.
Thanks for the good replies.
Jim.
