RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 08-27-2024 | 07:18 AM
  #2458
E-man1
Hi
Maybe these photos will explain. As Dave mentioned you want to get the turbine 2 cm higher than mounting rails (upright position). The reason for this is that the thrustline in this model is wrong.
The pipe/cone is fastened to the rails. The pipe outer pipe wall will touch the servo mount, but this is ok. I even sanded away some of the bottom former at the servo mount to get the pipe angle as i wanted.
In the rear you just let the pipe run through the model. No mods needed
Eirik
