RCU Forums - View Single Post - Securing spark plug cap.?!
Old 09-13-2024 | 06:14 PM
LLRCFlyer
You stated your engine is several years old. Most older carburetors use diaphragm and gasket materials that are not compatible with ethanol... so... you will need to either find a source for 100% gasoline (preferred) or verify that your carburetor is compatible for up to 10% ethanol fuel. Even if it is compatible, ethanol fuel goes bad rather quickly as the ethanol tries to absorb moisture from the air.
FishBreath (09-13-2024)
