RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 09-20-2024 | 07:56 AM
  #2183
mk13
I tried with the "evaporated" gasoline, no change.
I did an other test without the valve in the fuel line, the engine run not bad, and stayed running a long time without cutoff :
I will do an other test with the valve connected to the fuel line but not electrically connected.
The aim is to identify if the problem is due to valve running or only by the housing cavity
