Also crashed mine in late June after a loop and lost which was top or bottom. Straight down into a muddy ditch. The fuselage had a lot of long crack damage to structutre and sheeting, the firewall came off, wing blocks extracted, and more but it was repairable. Cowl busted and the motor filled with mud from end to end inside. Took a hose to the motor to flush out the mud from the magnets and coils. Luckily I had a replacement cowl.
After many hours, here it is in fine form again. Despite the repairs, it weighs exactly the same as before, 5 lbs - 5oz. with the same Power 32 4s 3700 mah setup. Remaidened yesterday and it still flies great. The motor works same as before.
