Well the bottom wing is getting the glue. Decided to thin the Sig assembly glue and brush it on along the spar so it will wick in place. I was talking to another builder and he suggested it was a great way to assemble with a Toung and grove. The trailing edge and top cap on the front spar looks great had to do a little sanding the four center ribs of the bottom wing are covered in sheet Balsa. Noticed a knoch was cut in the center thinking the fuselage strut was attached, but it’s not, just one of the got Chas! I may use 32nd ply on both sides of the spar. In that area, to strengthen that spot. Best study the plans again being three fairly large sheets I’ve hung them on the walls so it’s better to study as I assemble. I shall return! AJ
