Originally Posted by
mk13
Hi!
Some news about my plane converted with the 25LA (without solenoid), I flew a few days but the last attempt my wing broke in two parts because of a structural weakness.
The plane frame was ok for repair. So I adapt a Calmato wing and change the engine for a 40FP and reinstall the solenoid.
With this engine the small bubbles like dust that come from the solenoid have no effect on the engine operation.And now I can use the solenoid, and fine-tune the engine operation. So for me the 25LA is too small to work with the solenoid because of its sensitivity to small bubbles.
Very happy to hear that the .40 responds well to the solenoid.
I still think it is not so much the size, as well as the fact that the engine is bushed, and there is more heat generated in that area. The 40 is bushed as well, but the larger mass of metal, as well as the larger fuel flow mitigate the issue. I think a ballraced .25 would work OK on the solenoid, and for me, your experience with the LA 25 will be included when other people inquire after a set.
But that is all less relevant, happy to see that the solenoid is doing its job, and I am sure you will find, after some careful tuning, a much cleaner running and better responding engine as the result.
Please keep us posted on your experiences, good or bad, so we can learn from the good things and help solve the bad things.
