Well I started the Fuselage, laying out al the parts there are several, in this assembly. But strangely enough I am having trouble getting all the parts to line up. According to the plan. Being my age I thought maybe I Lost it. My Brain is not working. But no My neighbor came over and looked at what I was seeing and agreed ya somethings ain’t right here. So a new plan to adapt adjust and overcome this. The only way is to assemble all the attached inner pieces and then attach the sides. We both looked at the plans and realized some tabs will have to be removed in order for the firewall. Tank area and bell crank to all fit. Several pieces in the Belcrank area will be adjusted to work. Nothing is matching up, the program looks good, but the lazer cut inserts are in the wrong location, and don’t match up with the slots and inserts. My neighbor agreed the lazer cuts were in the wrong location. And the main Belcrank board is just to warped to work. But the design reinforcements would make it stronger. But nothing lines up. In the lazer layout. Infusing but repairable!AJ
