RCU Forums - View Single Post - Pat King 45% Flying Fool
Old 11-09-2024 | 09:27 AM
AJ Sun
Well this AM the fuselage sides got mated to the engine and fuel area and the top control horn mount plate. Used 30 minute Epoxy on this assembly and doing a tweaking had to clamp this entire assembly. About 12 clamps in all, I think it’s going to assemble pretty well, my fuselage strut for the upper wing and lead outs will come next. And finishing up the Belcrank mount and might as well do that assembly. Using wire lead outs. On this one the want a four inch bel crank. I will go with the three inch Brodak plastic model, and use some metal spacers king he wants a pin arrangement. With looks like soldiering washers on the top only. And dropping the pin down to the bottom Bel crank mount. I’ve got brass pin material K&S. AJ
