I powered from an alternate source and still get telemetry warnings, but haven’t run it yet. Interestingly, if I take the Hall effect sensor and place it directly next to the receiver the ecu reports 6600 rpm. I have a strong suspicion this is the issue. I’ll separate everything much further and see what happens. The Hall effect sensor is extremely sensitive.
Originally Posted by
scoeroo
Went thru a similar issue recently running everything off one battery , issue went away when each device was powered separately
