RCU Forums - View Single Post - Powerbox Core radio and set up thread.
Old 12-16-2024 | 12:29 PM
  #2008
dvcam99
Originally Posted by Brenner
I attempted to use it. I created a text file with a schedule of maneuvers on my PC, and then copied it to a USB stick. I then tried to use the file manager on my Core radio to copy the text file to my radio, but I kept getting a message telling me that the copy operation wasn't allowed. I then tried loading the text file into Anchorman directly from inside the Anchorman application, but that wasn't allowed either. I'm sure that the Anchorman application works, but until Powerbox fixes this file copying bug I won't be able to use it...
Hello Brenner,
the Anchroman PC editing works if you stick to the follow format. Example:
Test List.txt;
Figure M;0;
Looping;0;
Roll;0;
4 Point Roll;0;
Humpty Bump;0;
Test first Line is the file name. The following lines were made on a PC simple text editor. Please do not forget the separating signs like point and semikolon.
You can use the above example for a quick test. Drop these lines in a simple windows editor and save it with the file name "Test List.txt" on a USB stick. Open the Anchorman and import the file.
BR
Dirk
