Originally Posted by
dvcam99
Hello Brenner,
the Anchroman PC editing works if you stick to the follow format. Example:
Test List.txt;
Figure M;0;
Looping;0;
Roll;0;
4 Point Roll;0;
Humpty Bump;0;
Test first Line is the file name. The following lines were made on a PC simple text editor. Please do not forget the separating signs like point and semikolon.
You can use the above example for a quick test. Drop these lines in a simple windows editor and save it with the file name "Test List.txt" on a USB stick. Open the Anchorman and import the file.
BR
Dirk
Thanks for the tip. As soon as Powerbox fixes the file copy bug, I'll try what you suggest. As of right now, I am stuck just getting a file onto my Core...
