Too bad you can't post a picture or two yet(not until you get 10 or more posts due to issues from a while back) so we could see how things look. If the hardware is damaged, you might be able to replace it with quality stuff from Speedmaster or a couple other manufacturers.
As for the radio gear, if it doesn't work, replace it. Here's a link to Futaba USA's surface systems that they have available:
https://futabausa.com/product-catego...rface-systems/
If one would work for you, order it directly from Futaba, along with servos. If it works better, like the one your wife uses, you're good to go.
