RCU Forums - View Single Post - Confused about trimming
Old 01-13-2025 | 05:48 AM
Joe Peterson
Hello, as I am a beginner in it, nevertheless I found a checklist
- The radio does remember trim settings (mentioned in a comment above), but resetting the trim to neutral after the flight is a good practice to keep everything balanced.
- Yes, you can adjust trim while on the ground in Experienced Mode before flying, which can help you feel more confident and controlled when you take off.
- If you're still getting accustomed to experienced mode, practicing on the ground is the safer route.
