RCU Forums - View Single Post - CARF Bolt! Build thread
Old 01-15-2025 | 12:39 AM
  #181
RCUser012
Guest
My Feedback: (73)
Originally Posted by MarinusV
Hello everyone,
I'm a little confused about the duct of the turbine. I use a JetCat 250 Pro S - do you have any experience with the temperature? Doesn't the turbine get too hot in the confined space?
when the turbine is properly spaced fore/aft, you end up having optimal airflow through and around the outside of the turbine. You will not have heat issues. I have a P250 and one and a K260 in another.. the bypass area is barely ever warm and that is only after shut down from the ambient heat .
v
