Originally Posted by
GREMOS
in my flash (evo version) i am running a K142G4+ and i gott 448km/h(278mp/h),my engine is 24mm from the start of the straight pipe.i am thinking of getting it a litle bit closer cause when i use smoke,some oil is going inside the model.any thoughts about it??my nozle is deep in the pipe though.
whatever you’re using to calculate your speed is probably off. No way you’re getting that on an Evo with a 142 unless you’ve installed the full bypass. Even then the most I’ve seen with a 140 on a no -Evo is 247mph
