RCU Forums - View Single Post - CARF Ultra Flash Evo build thread +
Old 02-03-2025 | 09:17 AM
  #871
GREMOS
Originally Posted by camss69
whatever you’re using to calculate your speed is probably off. No way you’re getting that on an Evo with a 142 unless you’ve installed the full bypass. Even then the most I’ve seen with a 140 on a no -Evo is 247mph
i am using PB gps sensor.i have testet it with 2 other hand held speed sensors and they are in the range of +- 5kph between them with the same amount of satelites registered at.(10 average).i was in a slight dive and had around2-2.5 bf tail wind.
