RCU Forums - View Single Post - Help ! delay throttle bout' 10 second
Old 03-04-2025 | 10:13 AM
daddytoo
Default Throttle stick delay. IX20SE
I would like to have a 10sec delay on my throttle stick to stop the ESC from arming the motor on my 3mtr Fox glider. The glider is to heavy to lunch with 1 hand so to activate the 10sec delay I would like to programe a mix on switch A so I can pick up the glider with 2 hands and steady myself. Flick the switch A to on and the delay will run down and start the motor with me holding the glider with both hands can this be done many thanks.
Originally Posted by Bax
You cannot do that with the 18MZ. You can use a condition to delay how long it will be until the condition becomes active, but not one to move the throttle up then down. You can adjust how fast the servo moves with stick input in a condition, but the servo will always run at that speed as long as that condition is active.
